Yes, the DB-8e has two panels, each of which can be aimed separately.
But the DB-8e is for UHF and you have several VHF-HI stations (11-PBS, 8-NBC and 10-ABC). If you're going to use the DB-8e for UHF go with something like the Antennacraft Y5713 or Y10713 for these stations.
For the DB-8e aim one panel at about 52 degrees on a compass (midway between 17-Ind and 35-KRSU) and adjust either way until you have what you want. Aim the other panel at about 160 degrees. Most stations are concentrated between 122 and 158 degrees but 28-ION is at 168 degrees. That's a pretty wide spread so you might not get everything (you can also forgo the stations at 58 degrees aim one at 135/140 degrees and the other at 182 degrees for 28-ION).
Others will also post. Wait for a few experts.
