Old 13-Jan-2015, 9:20 PM   #9
Tower Guy
Originally Posted by timgr View Post
My intuitive understanding of this is that the two antennas will create what amounts to an amplified multipath. I'd guess that you could move the two antennas around and change the degree to which that multipath is present. But that change might improve one station while others deteriorate.
I would try it if I had the materials on hand, and time to experiment some.
That sums it up pretty well.
One trick to try to add WUNC without causing multi path on the other stations would be to use vertical polarization on the WUNC antenna. WUNC just happens to be transmitting with both H and V pole signals.
