Old 13-Jan-2015, 5:08 AM   #6
tally
Thanks all for the replies. There is really no pattern other that what I stated in the first post. It always happens every 3 minutes or so. I am not in the path of aircraft approach. Based on the above responses, it is either the pines I mentioned above or it could be the connector at the antenna. If it is the connector, I am not scaling the roof until it warms up here in Minnesota! As far as the pines go, what I know for sure is the antenna is pointed right at them. When I installed a few years ago, the antenna probably just barely cleared the top of the trees. We have had two growing seasons, so I am betting it could be the pines.
tally is offline   Reply With Quote
