Old 12-Jan-2015, 8:30 PM   #3
If it's the trees, wind and moisture on the trees will generally make the symptoms more pronounced.
Aircraft flying past may account for such symptoms. They reflect signal, causing a form of multi-path interference at your antenna. You mentioned a regular pattern... Are you under the flight path of the approach to a scheduled airport?
As already mentioned by ADTech, moisture in a connection of matching transformer will produce degraded system performance. The simple test is to disassemble, inspect and substitute known good parts in place of the potentially compromised parts. Generally, a cable with moisture inside the jacket should be discarded, it will have been permanently damaged due to corrosion.
