Old 12-Jan-2015, 1:16 AM   #1
tally
Was perfect / Now Audio Dropouts and Pixelation (SOLVED BELOW)
This is my Signal Analysis:
http://www.tvfool.com/?option=com_wr...46aeb18652e11a
I am using this antenna: RCA ANT751
My signal was fine for two years. This past month I started getting occasional pixelation and audio dropouts. This occurs on every channel and it happens about once every three minutes for about 1 second or less. The hd image looks great all the time except when the incident occurs. The pixelation is very slight. The signal on my antenna meter on the TV shows full bars.
The is a group of 2 pines in line of sight of the antenna (just the top of the trees) about 75 yards away. The only thing that possibly happened was the trees grew a bit.
Could it be the pines? Not sure where to start here but i would rather not raise the antenna as it is cold here; and I will probably wait until spring. I am splitting the signal (only two locations in the house).
At any rate, should I temporarily try a booster and what kind?
Any suggestions on what the issue could be other than the pines? Thank you.
tally is offline   Reply With Quote
