Ok thanks, I'll forget about hte omnidirectional option.
I did try to connect both antenna to a simple two-way splitter in reverse but one of my cable was longer than the other and I was receiving very poor signal. But they weren't at a right angle but close since they were at ~100 degree. I guess I'll have to try with same length cable.
Since the signals I'm interested in are 280 degree and 175 degree, I tried setting the antenna at 230 degree but the signal was poor. I was going to ask how wide does a unidirectional antenna can cover, but I guess it depends on the antenna, right?.
If I put a reflective board behind each antenna, will it help to block behind the board signal?
