Thread: Home Antenna
Old 11-Jan-2015, 4:59 PM   #2
The signal levels and path conditions shown on your TV Fool report imply that an attic mounted antenna may not be capable of producing reliable reception. An amplifier is not an antenna, it can not and will not make any antenna more sensitive or able to 'pull' signal from the air. Amplifiers are only able to increase the power level of the signal + noise + interference fed into the amplifier. The amplifier will also distort the signal further and add some noise over and above the original. Reliable reception starts with choosing an antenna and mounting location. If you opt for the wrong antenna (too small or wrong type) or mounting location, amplifiers and other accessories will often be as effective as a band-aid on a broken leg.
I'd suggest you test reception outdoors. If I was starting from scratch, I would be inclined to use an outdoor mounted combination such as an Antennas Direct DB8e + Antennacraft Y10713 + UVSJ. The length of the cable run(s) and the number of TV's connected would inform the decision re. What amplifier if any should be used. An amplifiers job is to deal with loss that occurs downstream of the amplifier.
