Old 9-Jan-2015, 3:34 AM   #1
bohiti
Quick question regarding attic placement..
http://www.tvfool.com/?option=com_wr...2c1574ac5781a5
27 is my main challenge/goal, I think the others are easy enough. Have a DB8e and Y5713 on the way, TVPRAMP1R to combine/amp.
Despite the downsides of attic installation, its going to be my first effort. Wondering if you all can save me a few hours of work with your gut instincts:
I have two attic areas I can try.
  1. Above the living area. Wading through nasty blown insulation, yuck. Will be able to get a north-bound view (transmitters ~ north) through the side of the house (plywood/vinyl siding), mostly not through shingles. Will have some partial blockage from neighbors house.
  2. Over the garage. No insulation to wade through. Can get up 5-8 ft higher. Will avoid the neighbors house better, but north-bound will be through shingles. New house with standard materials.
Which would you try first? Prioritize on avoiding going through shingles or the neighbors house?
I totally understand no promises can be made. Appreciate your thoughts. Thanks!
bohiti is offline   Reply With Quote
