Tv Antennas and Reception
The best way is to run a coax from each antenna to the Tv location and connect the two coax to a Remote control A/B antenna switch. With the A/B switch there will be no interaction between the between the two antennas. If you use a two way splitter in reverse then some of the signal will go to the other antenna and not to the Tv. And cross talk of the antennas will happen with a two way splitter in reverse. If a isolation type combiner is used some signal strength will be lost in the combiner. . An A/B switch is the best.
