Old 7-Jan-2015, 6:40 PM   #2
I'd consider the Winegard HD7084P or Antennacraft HD1800. Channel Master has similar product. These can be considered a premium option, but the added gain is insurance and may very well eliminate the need for any amplification.
Antenna gain is superior to amplifier gain. Amplifiers add noise to the signal while amplifying any noise or off angle signal / interference received. A high gain antenna does not add noise to the signal and it reduces the amount of received interference if the interference source is from a direction other than the antenna is pointed toward.
