Old 7-Jan-2015, 3:01 AM   #4
If you are limited to an attic install for what ever reason, the edge path conditions and marginal signal strength reflected in your TVFR argue for using a high gain antenna such as the DB8E. The only way to know if it works is to put an antenna in your attic.
In the Seattle market, KCTS-9 and KSTW-11 would be at risk if you opted not to use a second antenna such as the Y{X}713 types mentioned by timgr. KCPQ-13 simulcasts on real CH-22 from Capitol Hill (the weak signal on real CH-22 at your location is not very promising for an attic mounted antenna though) so a UHF only antenna may be a valid solution if you have no interest in CW and the Seattle based PBS channels. KBTC is an alternate PBS option that might be received with a UHF only antenna.
