Old 7-Jan-2015, 12:40 AM   #3
enph
Thanks for your insights, timgr.
Rooftop application is not possible due to living in a townhome/condo and the HOA restrictions. We could place it on a tripod on the patio however it then becomes an eyesore and is not preferred. It would also likely be considerably lower.
I will investigate the combo antennas, as I haven't been focusing on that market segment and (as you pointed out) probably should at least consider it.
Thanks again!
enph is offline   Reply With Quote
