Attics can be acceptable antenna mounting locations if you're lucky. They can be horrible black holes also.
Consider testing reception outdoors. You'll avoid the signal attenuation of the roof deck and/or walls as well as reduce the amount of electronic noise generated by the various electrically power equipment in the home.
