Old 5-Jan-2015, 1:26 AM   #3
JohnnyP
Thanks for your quick reply! Once I read your reply I started to research more into other options (just to compare other brands not that there is anything wrong with your recommendation) and I found this,
http://www.channelmasterstore.com/Ma..._p/cm-5016.htm
to my understanding it covers the 54 to 216mhz range and that would be suitable for me to pick up 3?
To answer your question I could attic mount as I have a way to run from the attic to the basement and back into the wall to the TV. Its single story and it would be less the 50ft run to my main TV.
Since I have your attention, is there anything special I should use as far as a splitter to connect multiple TVs?
JohnnyP is offline   Reply With Quote
