Old 4-Jan-2015, 11:02 PM   #4
woodardhsd
Originally Posted by timgr View Post
So did your antenna work in the attic location? Certainly I would test that before proceeding. An "attic antenna" is just a cheapened outdoor antenna - not weather proof. There's no way to design an antenna specifically for attic use that's different from outdoor use, other than you can make is flimsier. So consider whether you are getting good value from the GE antenna, compared to, say, an RCA ANT751. http://www.amazon.com/RCA-ANT751-Dur.../dp/B0024R4B5C - which also should be available from Walmart.
The signal strengths in the first post are with the GE antenna.
Should the RCA do a better job picking up those signals?
woodardhsd is offline   Reply With Quote
