Old 4-Jan-2015, 9:22 PM   #1
ctresident
Reception Help in Newtown, CT WTIC and WFSB
Currently have Antennas Direct DB4e in attic. Do not have a split on the antenna now, but may split from source to 3 TV with the longest connection being 50 feet. Looking to get advice since I can not get get the following stations. Will move the antenna to the roof when the weather is warmer.
WTIC real channel 31, 29 miles, 43 degrees, Nm 43.4, Pwr -47.5, LOS
WFSB real channel 33, 34 miles, 39 degrees, Nm 24.5, Pwr, -66.3, 2Edge
Should I add an amplifier and which one? Should I change the antenna when I go to the roof, or add a second directional antenna? How is connecting 2 done? Link for report is here.
http://www.tvfool.com/?option=com_wr...2c15428b1dc31e
Thanks in advance.
ctresident is offline   Reply With Quote
