Old 29-Dec-2010, 11:20 PM   #10
One Tv thats good , no conflict with others about the Tv stations the rotor and antenna is pointed at. The best way to connect the two antennas to the Tv is to bring a RG-6 coax cable from each antenna to a Remote control A/B antenna switch located close to the Tv. The most often used roof top antenna mounts are the tripod mount , chimney mount , eave mount . . The metal of the second story will disrupt the Canada Tv transmissions so the antenna needs to be above the second story. . http://www.solidsignal.com , http://www.starkelectronic.com , http://www.amazon.com , http://www.3starinc.com
