					Originally Posted by  kdub
				One quick additional note - the antenna in the current location in the attic is already as high as I can get it, moving it outdoors will not really net me any additional height for obstruction clearance unless I look to put up some sort of tower for the antenna to sit on. The only real gain I will get in moving it outside is to avoid any attic interference and be able to better point it more directly towards the signals. (at least, that is my assumption of the gains I would get - if I am missing something I would be glad to hear it!)
 Well, going outside the attic you will gain signal strength on the direct LOS path to the stations. Again, it's hard to predict what will happen... you could also gain strength in the multipath directions and see no change. However, I'd expect that increasing the strength of the LOS path would be the most likely path to improvement.
