Old 2-Jan-2015, 10:02 PM   #6
timgr
Originally Posted by kdub View Post
Also - one more note, it was mentioned to rig up a dipole kit for the WHAS signal - I am assuming that this is due to it being a VHF signal. The interesting thing is that I have never noticed any issues with that station. The two that I have noticed issues with are the WDRB and WLKY stations (both UHF). Not sure if this adds much to this conversation but thought I would mention it anyways.
Yes -
I think that supports the idea that you have a signal quality issue, not a signal strength issue.
A UHF antenna will not be deaf to VHF, but because it's not designed to be resonant at those frequencies, it will be significantly less sensitive then at its target frequencies. If you have lots of signal in the air, the lower sensitivity won't matter, and the VHF signal will be above the threshold for reception.
