Old 2-Jan-2015, 5:18 PM   #4
Hamilton Ham
From your location you should get all the Hamilton, Toronto stations. Unless I'm mistaken, you can see the Toronto skyline (CN tower) through the branches of the tree on the left of your picture. I would look for a bad cable or connector between the antenna and TV. I would be suspicious of the connector right at the antenna since you get CFTO. BTW tomorrow's temp +4 and Sunday +10. Good for outside work on the antenna. Can you try something as an antenna plugged directly into the TV? This should give you almost all the channels, given your location, to help you isolate the problem.
Hamilton Ham is offline   Reply With Quote
