Thread: Preamp dead?
Old 31-Dec-2014, 10:37 PM   #3
rickbb
I ran home from work and replaced the power injector, same result. So I went up on the roof to replace the preamp and thought lets see what happens with no preamp at all. I disconnected the amp and power injector, both TV's are running just from the antenna.
I did this when I first built and mounted the antenna but results were not great which is why I ordered the amps. This time after running auto scan on both TV's I'm getting 40 channels on the living room and 30 in the bedroom. No amp at all. Go figure. I did tweak the runs and direction of the antenna since then though.
I'll let this run a few days this way and see what happens. For now it looks like I won't need an amp after all.
I'm off tomorrow and will pull all new cable for the antenna since I'm using the existing cable that the sat installer put in. I can shorten the run to the bedroom by quite a bit that way and should be able to pick up the other 10 channels that I'm getting in the living room. I need to ground the mast and coax anyway.
Still strange that it ran fine for 4 to 5 hours before going wacky on me. Maybe it was overloading all the time?
