If it affects only the UHF and not the VHF, and comes and goes with movement of the antenna using the rotor, and the amplifier is located below the rotor (and is stationary), then it seems likely that there might be an intermittent connection somewhere between the antenna and the UHF input of the amplifier. I'd check the connections at the antenna and the amplifier and even replace the coax before buying anything.
