Old 31-Dec-2014, 5:10 PM   #14
Tim
Originally Posted by JGoodwin View Post
http://www.tvfool.com/?option=com_wr...d243ffb9e0244e
Do you think I can put the Antennacraft Y10713 in the attic and the Antenna direct DB8e on the roof or will the attic block to much signal?
Looking at your report, it looks like both of them need to be on the roof. You should separate them about 4 feet apart on the mast or more. By the way, the Y10713 is for Hi VHF channels 7-13. If you are looking to pick up channels 2, 3 and 6 you will need an antenna for Lo VHF.
It will help everyone make better suggestions if you will tell us which stations are your "must haves".
