Old 31-Dec-2014, 12:19 PM   #2
Would any of the indoor antenna's that you hang on the wall or window work?
Probably unreliably. At 30 miles, indoors, and with a 2-edge signal path, you don't have much margin for success. If you have trees and/or neighboring homes in the signal path, your margin for stable, reliable reception plummets as clutter loss in the signal path increases.
What kind of antenna would I need?
The numbers say that a small high VHF/UHF combo is needed, probably attic or outdoors. The currently unknown variable is the previously mentioned possible clutter loss about which we know nothing. If you have an open field in that direction, reception will be easy. If you're looking into trees or your neighbor's house, not so much.
