Old 30-Dec-2014, 7:07 PM   #2
You do not need a Stacker as the top half of it would be completely useless for you.
All of your available channels are on VHF channels 2-13. Only one company still sells a 2-13 antenna and that's AntennaCraft, model CS600. Don't forget to also order a matching transformer, the antenna doesn't come with one. You do not need an amp.
Aim the antenna a bit to the left of due north and you should be able to pick all the available broadcasts which should net you a total of 10-12 total channels that are all re-broadcasts from out of Spokane.
