Old 29-Dec-2014, 11:42 PM   #8
Tower Guy
Originally Posted by Desert Rat View Post
Turns out it would not work at all anywhere above 5-6 feet.
I went back to the TV Fool report, and sure enough, if I put in 1 ft. antenna height it gives me better numbers than 10 or 20 feet.
The formula used to calculate signal strength in TVfool does not use ground reflections to figure signal strength. Yet ground reflections can add up to 6 db to the signal strength.
Read the paragraph "Average Power Diagram for UHF" in the following web site:
In your case, the signal enhancement near the ground is even more pronounced than the picture shows. I'd assume that the TVfool calculation of a stronger signal at ground level is a coincidence.
Consider an old umbrella stand for your mounting pole. Others use concrete in a 5 gallon plastic pail.
