Tell us about where you have the antenna - how high, line of sight (LOS) to the stations you want, aimed in the directions you want, indoors/attic/outdoors, trees buildings or other obstructons in the way ... the stations you refer to are mostly strong and any reasonable antenna with proper siting should be able to pick them up.
Note that a bowtie is typically a UHF-only design, so you could expect trouble with CFTO rf 9 in particular. But it's a strong station there, and likely to be picked up even though it's out of band for the antenna.
Also I'd suggest that you resolve your address exactly. Suggest you use the "start maps" on the front page and place the cursor as exactly as you can, then button "make radar plot" and post that link. Your exact location won't be shown on the plot.
