Thread: Amp cutting out
Old 27-Dec-2014, 6:39 PM   #7
TDiddy
Ok, so I spoke with the company that installed the antenna.
They confirmed they did not install a pre-amp on the antenna. He says the cm 0747 ... Which is discontinued, as you know, and is hard to get a hold of now, for some reason works great in boosting the signal when there is a long cable run... Over 50 feet in his experience.
He said the signal strength is great at the antenna, but it loses strength over the run of the coax. The cm 0747 simply pulls the signal along.
Does that make any sense? If not, some advice on the ideal setup based on my antenna (CS2), location and cable run of 65 feet would be appreciated.
TDiddy is offline   Reply With Quote
