Thread: Amp cutting out
Old 27-Dec-2014, 6:23 PM   #6
It's actually persistence in emphasizing that you have what appears to be either an illogical or an incompletely identified configuration. If installed by itself, the 0747 will do only two things: 1) Apply an unneeded +18 volts to the coaxial cable at the output (antenna side) of the 0747 and 2) Provide a dB or 2 of attenuation of the input signal. There's nothing else it can do.
Until the confusion is eliminated it's pretty much impossible to identify the issue with your reception.
