Thread: Amp cutting out
Old 27-Dec-2014, 3:21 PM   #2
As I explained in your other thread, the 0747 is only the power supply, it is not an amplifier. You need to find out specifically what's mounted up on the chimney.
Based on your TVFool plot, you should absolutely NOT be using a pre-amp indiscriminately, especially the CM7777, as your close by stations from the CN Tower will overload the amp and cause a LOSS of reception.
