Thread: Amp cutting out
Old 27-Dec-2014, 3:15 PM   #1
TDiddy
Amp cutting out
http://www.tvfool.com/?option=com_wr...2c153742f6ab97
Hey all,
I have a ClearStream 2 antenna, and until recently it has worked brilliantly. I can get upwards of 40 stations. But about one year after I has it installed, the signal dropped and I only got 3 local stations.
The installer put a CM 0747 amp on the cable inside the house that really helped boost the signal. I assumed this unit had failed, and that was the problem. So I ordered a replacement 0747 ... and it worked perfectly for about 2 weeks, then it stopped working.
Then I ordered the 7777... and only connected the power supply. My antenn is on the top of my chimney, and I am not comfortable going up that high.
Simply connecting the power supply worked great, for a couple of days... but then it stopped working and I went from nearly 40 channels back to only 3.
Any idea what is happening here? It does come back on from time to time for a couple of days before cutting out for a few days...
The antenna is on the chimney, I have about 65 feet of cable. And it is split 3 ways about 15 feet after the power supply
Thanks!
TDiddy is offline   Reply With Quote
