Old 26-Dec-2014, 8:21 PM   #2
mmorris
I should add that I can receive 3, 8, 12 & 23 with a ramshackle (bent and loose) antique roof mounted directional antenna, without a rotor (I could receive 6 before the “windstorm of ‘08” damaged the antenna). I haven’t done any testing since the analog/digital transmission change, but I needed a rotor with analog transmissions to get clear reception.
This is a rural area. It's hilly and forested, but I am on high ground. A little movement of the antenna location changes the report, so I am guessing the results are questionable?
I have a rotor, and the house is wired for rotor controls, but I want unattended recording if possible
As I understand it, these are some possible options:
-Omni
-Multiple fixed antennas with combiner
-Multiple fixed antennas with A/B switch
-Single directional with rotor
Are there any affordable ways to coordinate antenna rotor control and station selection on the tuner?
mmorris is offline   Reply With Quote
