Old 26-Dec-2014, 2:30 PM   #5
no loss in combiner and phasing harness for the DB8e - how far from reality is that assumption?
Not very far, the combining is pretty efficient.
with the Y10-7-13 over the DB8e?
Put whichever one provides the best results on top. Traditionally, the UHF antenna gets put on top, but that's never set in stone.
I would probably try manually rotating the mast
That's a good compromise to see what's possible. Keep in mind that big antennas are going to need a very robust rotor.
Any reason to consider maybe a PA-18 amplifier instead of the CPA-19 I already have?
Not really since you already have the CPA19. The PA18's noise figure would give you less than a dB of advantage in system noise figure so I'd suggest sticking with the CPA19 for your initial tests.
Is there a better recommendation for a low noise amplifier with independent UHF and VHF inputs?
Antennacraft and RCA are your only current model choices. You might find a discontinued Winegard or Channel Master on ebay if you're patient enough to wait for one to come along. In reality, using an external UVSJ of good quality with a low noise single input pre-amp usually won't make much of a difference in the system noise figures.
does it make any sense to use my Motorola BDA-100S4 as an amplified splitter
Only if it's needed. Let's get some reception first before expanding the system.
