You need an EAST wall or window for it to be more predictable. If you're on the "wrong" side of the building and the building's construction or surroundings do not allow the signal to reach the antenna, then you cannot get reliable reception. Yes, buildings and your surroundings can do that.
Many of your signals, plus all the local FM signals, are very close by. You cannot use an amplifier as most will overload and cause a loss of reception.
