One antenna?
Thanks for the reply. Do you think a single antenna such as the 7968P has a chance of doing it all? I can locate it anywhere on the large roof on a nonpenetrating roof mount and even add a couple of 5 foot mast sections.
If that doesnt do it, I could combine another antenna or stack another.
I was going to use a CM7777 pre amp and then split to north and south closet runs at 4th floor. What is the best distribution amps to use at each floor?
I just hope I get the signal strong enough to feed the whole building of 48 condos - if everyone signs up for it.
--James
