For something the size of an aircraft carrier (14' long by 10' wide), you'll likely pick up WRUF-LD and maybe W07BP additionally and that's about it.
Your existing antenna is better on UHF, you're already getting almost everything possible on high-VHF, and there's only one station on low-VHF.
If the amp is a good one that doesn't overload easily, you'd probably be better off keeping your existing antenna and using the rotor and pre-amp. The other antenna can be recycled into something I consider more useful - beer cans.
Good luck!
