No success speaking with WREG engineer.
What does that mean? That you couldn't reach them or you reached them and they said that nothing was wrong on their end? If the former, keep trying as you may otherwise expend considerable resources on trying to fix something in your system when there's nothing wrong with it. If the latter, relocate the antenna and try again. Better yet, get the antenna out of the attic and up in the air. At 67 miles, a UHF signal isn't expected to be reliable in an attic.
Whatever the issue, it's going to either be with the station itself or your setup, including your surroundings.
