Old 20-Dec-2014, 10:17 PM   #10
Tower Guy
Originally Posted by shawnhanson View Post
Ideally, I would like to get one of each of the main network channels, but my focus would be on FOX and CBS.
Try an HBU-55 aimed at 208 degrees. The second step is an TVPRAMP-1R preamp. If you are not happy with the results, then move it to the roof using an eave mount or a wall mount below the eave.
The addition of a Y5-7-13 aimed at 81 degrees would allow for your Silicon Dust tuner to find two CBS stations without re-aiming or re-configuring anything. The VHF/UHF combining would done in a channel 8 Jointenna. http://www.channelmasterstore.com/JO..._p/cm-0578.htm
The advantage of two CBS stations is that WKBT may air different NFL games than KIMT. Here's an example from November 9, 2014. http://506sports.com/nfl.php?yr=2014&wk=10
This plan works well for a Vikings fan. Yet if you wanted the Packers, you'd need an antenna to pick up WLAX. http://506sports.com/nfl.php?yr=2014&wk=16
