Thread: Antenna help
Old 20-Dec-2014, 5:01 PM   #3
Even before that, you need to identify which stations you are getting and those that you are not getting but you think you should. If you're already getting all of your desired local stations with your current setup and there's no realistic probability of getting more except as an experiment, you'll need to decide if the extra work is likely to be worth the effort.
If nothing else, the rotor would probably be the most valuable part of the package to your location.
