Old 20-Dec-2014, 12:38 AM   #9
timgr
You are somewhat limited with the VHF band. The long wavelength of the VHF signal implies that you need an antenna with a similar length. You could maybe use the Antennas Direct ClearStream 5, which has a different form factor from the long Y10713. It trades off large in a planar sense for the length of the Y10713. https://www.antennasdirect.com/store...V-antenna.html It is also considerably more expensive, and its stated gain is lower.
