Old 19-Dec-2014, 6:27 PM   #11
tomfoolery
Originally Posted by hef View Post
Ok I see what you mean - so the tv antenna location is on the right, the Transmitter on the far left?
Yes.
How can you tell the TV antenna is below the large hill? Where is it referenced in the graphic?
I don't know for fact, but I've always assumed the 'ground' is represented at zero local elevation. With the Pinnacle Hill transmitters approaching 400 ft height above average terrain (HAAT), which I read somewhere when they used a 400 ft crane to modify WXXI's antenna to remove that off-center cross bar, a 20 ft high home antenna would eyeball-scale to 1/20th the height of the transmitter, at the center of the white. Which makes the home antenna barely above ground level, at least in the scale of those coming from Rochester. So that pretty much puts you deep in the shadow. Or so it looks to me. But even with 1-edge and 2-edge conditions, you may be able to get some of those stations, though it doesn't look promising.
tomfoolery is offline   Reply With Quote
