Old 19-Dec-2014, 5:08 PM   #6
hef
Facing East...
Your only hope for a full set of affiliates is Syracuse. All the Syracuse stations are on UHF. My antenna recommendation would depend on the size/shape of the window. You may add the Rochester VHF stations with a Y10-7-13 installed in the optimum location for 335 degrees at least 5 feet away from the UHF antenna. Couple the two antennas with a TVPRAMP-1R.
Tower guy, the attic window faces East and is about 2 feet wide by 3 feet high. Would be interested in hearing your recommendation for a UHF antenna for the Syracuse stations.
I plan on giving it a try.
Thanks,
Hef
hef is offline   Reply With Quote
