My current setup is very similar to what ADTech recommends. I'm using a Antennas Direct DB8e and a Antennacraft Y10713 on the same mast, with an Antennacraft 10G221 preamplifier to mix the signal from the two antennas. I have both strong local and distant stations, so you could likely use the 10G222 which has higher gain than the 10G221. The RCA TVPRAMPR1 is also recommended frequently, inexpensive and high quality. Read about the gotchas with this amp though - goofy switch positions from the factory and breakable plastic case. Antennas Direct is also coming out with a preamp soon, so I hear - you might keep track of that.
Use your compass and point directly at Mt. Wilson, 81 degrees magnetic. If you can move the antenna around before you pick a permanent site, that could be helpful.
