Old 18-Dec-2014, 8:59 PM   #4
In addition to the excellent suggestions by GUM, you might consider replacing the Lightning rod with a static dissipation array. Commercial arrays are expensive, but you can roll your own with a chimney brush.
The purpose of a static dissipation array is to drain off any static before it builds up to the point that lightning occurs.
