Old 18-Dec-2014, 8:26 PM   #10
Yes, you can put the UHF/VHF signal into the UHF port, but only UHF will come out. The preamp filters out VHF from the UHF input, and vice-versa.
That's the case only if the switch is set to "Separate". If the switch is set to "Combined", EVERYTHING (except 250-400 MHz) comes out unless FM if the FM trap is in.
