re. grounding ahead of preamp
The insertion loss of a simple coax grounding block or even one with protection of the center conductor (see link below) should be less than 1 dB. I'd use the type linked to below, but expect it to need replacement if you get hit by lighting.
http://www.solidsignal.com/pview.asp?p=212ff75f225-21
You can see the lengths to which this can be taken...
http://www.nasa.gov/mission_pages/co...lightning.html
Reason: added link
