Old 18-Dec-2014, 5:57 PM   #8
docsuess84
I've pointed it everywhere and nothing changes. The stations I get (the green ones) are perfect and nothing else, even if it's not pointed directly at the tower. If I can amplify my antenna enough all I'm missing is NBC. I can live with that but I'd like to try. The issue with two kinds of UHF antennas was why I was curious about using diplexers. Rather than combine signals I'm just wondering if they can share my existing coax run and then separate at a diplexer connected to an A/B button in the living room. I just wasn't sure if diplexers could carry the same type of signal from two sources. On another note, when I go to replace the preamp since my VHF signals are full strength can I plug a combined VHF/UHF into the UHF port without issue?
docsuess84 is offline   Reply With Quote
