Old 17-Dec-2014, 10:33 PM   #5
timgr
Have you tried pointing at 147 to see what stations you get?
Usually combining dissimilar antennas in the same band on the same wire does not work well.
If you wanted to get a DB8e, for example, you could point one panel at 225 and the other at 162, and use your 5884 for VHF reception. The DB8e might pick up KRCR 7 and KIXE 9 even though they are out of band. Or you can use a dedicated VHF-high antenna and combine the signals with a UVSJ or the RCA preamp.
