Old 17-Dec-2014, 2:57 AM   #1
devidog
Will a different pre-amp help ??
http://www.tvfool.com/?option=com_wr...d2435829a52355
I have a db-8 and a y10713 into a rca tvpramp1r pre-amp and less than 50' feet of new rg6 with all compression fittings. I get all the stations I expected to get but I'm having trouble with fox 22. I'm guessing it comes and goes with deal conditions. The signal strength meter says about 45%. The uhf stations that I receive well come in at about 58%. My question is the rca pre-amp advertises 22db gain on uhf. The channel master cm-7777 advertises 30db gain. After using a splitter to combine the signals I'll lose 3db. The cm-7777 would give a net gain of an additional 5db over the rca. What are the chances of this pulling in fox consistently?
devidog is offline   Reply With Quote
