91XG also an option. It has a wider beam width and more gain down low (ch. 24, presuming you are looking for that NBC station @ 332 degrees), try to capture both angles on one antenna, split difference or favor #24. If KRCR-TV 7 is your only ABC then you need to look possibly for a dedicated VHF antenna. What are all the other channels in between, sometimes those are legit stations that are simply missing data.
